Displays liberally-retained labels received from a peer for either the Layer 2 VPN protocol or LSP protocol.
| ipaddress | Specifies an IP address. |
| ipNetmask | Specifies an IP network mask. |
N/A.
If no options are specified, tabular information for all liberally-retained labels is displayed. The following table describes the display fields that appear when this command is entered.
| Field | Definition |
| Advertised Label | Advertised Label is the label advertised to other routers. |
| Destination Mapping | Destination Mapping displays the destination IP address and mask. |
| LSP Flags | LSP Flags lists the flags for each label, which are described in the key at the bottom of the display. |
| Peer Label | The peer label that replaces the received label of incoming packets during a label swap on a transit LSP. The peer label appears only for transit LSPs. |
| NHop Type |
NHop Type helps define the handling of a packet arriving with the specified advertised label. Possible values are: IP—The label on the packet is swapped and the packet forwarded to the IP address shown in the NextHop field.locl—Indicates that the tunnel destination is local to this switch.VLAN—The label on the packet is stripped and is IP routed according to the Destination Mapping field.VPLS—The label on the packet is stripped and forwarded according to the service configuration of the VPLS specified in the Name field. |
| Next Hop | Displays an interface ID for the next hop router, which can be a VLAN name, VMAN name, or IP address. |
| Name | Displays a VPLS or LSP name. |
| Received Label | Received Label displays the label received from other routers. |
The following command displays liberally-retained LSP labels received from peers:
# show mpls ldp label retained lsp
Peer Peer Next
Prefix LSR ID Label Hop VLAN
30.30.30.0/24 3.3.3.3 0x00435 30.30.30.2 r1-r3
2.2.2.2/32 3.3.3.3 0x00439 30.30.30.2 r1-r3
22.22.22.22/32 3.3.3.3 0x0043a 30.30.30.2 r1-r3
10.10.10.0/24 22.22.22.22 0x00434 10.10.10.2 r1-r2
30.30.30.0/24 22.22.22.22 0x00438 10.10.10.2 r1-r2
1.1.1.1/32 22.22.22.22 0x00439 10.10.10.2 r1-r2
3.3.3.3/32 22.22.22.22 0x0043a 10.10.10.2 r1-r2
This command was first available in ExtremeXOS 12.5.
Peer LSR information added in ExtremeXOS 22.5.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
